Old 02-05-2019, 04:23 AM   #11
Bbasso's Avatar
Rob.
Current:
And had three other E350s...
Old 02-05-2019, 04:25 AM   #12
Bbasso's Avatar
There are no requirements for changing the rearend in order to get 4x4 in a van.
It's all about getting a front axle in and working.
Rob.
Current:
Old 02-05-2019, 06:32 AM   #13
The reason the Sterling axle is a popular rear upgrade for 4x4 vans, is starting in 2005 Quigley and QuadVan (and all U-joint conversions) started using the 8x170 bolt pattern front axle. The Sterling rear axle is also 8x170mm, so it eliminates the need for adapters to match bolt patterns.
Old 02-05-2019, 08:02 AM   #14
Agreed, you need an wheel adapter if you go with a FF from a van. I've swapped in full floats into two of my vans now.
Desert Solitaire
2003 7.3L EB 4x4
Timberline 4x4 conversion
Old 02-05-2019, 09:50 AM   #15
Thanks for the enlightenment guys.
Hi, I’m Robert and I’m a vanaholic…
2003 Astro AWD
1999 E350 RB 7.3 cargo
2002 E150 RB 4.6 hightop van conversion
1999 E350 RB 5.4 Chateau
Old 03-22-2020, 09:10 AM   #16
b. rock's Avatar
One year later bump...
I'm going to snag an axle next week so that if I get suck at home I can work on the van.
I found an axle on car-part that supposedly is from a 2007 superduty pickup, 3.73, with a locker. They added this note though:
"45"SP-SP,60"BP-BP" Do those measurement jive with a truck axle, not a C&C axle? It strikes me as odd that they put those measurements in there.
After having a guy show up from car-part with supposed full float axle and I had to explain to him that he in fact had a semi-float....my trust in part accuracy on there is only about 60%.
b. rock is offline   Reply With Quote
Old 03-22-2020, 10:13 AM   #17
I think that is a pickup axle. My notes say 41.56" spring center for cab chassis, 45" for pickups.
Old 03-22-2020, 05:42 PM   #18
b. rock's Avatar
Perfect, thanks!
