Originally Posted by daveb
Originally Posted by BajaSportsmobile
I could be wrong, but I would assume the they are always working in DC and only convert AC to DC when AC is available.
Yeah I think that is correct and assume the reason they are more efficient in the AC mode is there is a stable voltage supply when converting AC. I could be wrong but on battery power it runs between specific voltages and at a lower the voltage the compressor has to work harder. It would make no sense to invert DC to make an AC compressor work.
...cut......
Dave, I've been meaning to look into these small refrigerators to see how they work. I can't imagine the motor works on both 12 Volt DC and 120 Volt AC, so I assumed they likely use a 120 Volt AC motor and then invert 12 Volt DC when needed. Why do you think this wouldn't make sense?
It's about the only explanation I can see to explain why they would be more efficient on 120 Volt AC.
