I think the "standard" SMB build came with a 12 volt only, and the AC/DC model was a upgrade.
The older units had an external power brick, the newer units the conversion is done inside of the controller. The 101N0510 is a AC/DC version The DC only versions are usually 101N03X0, they have a couple of revisions. So if someone wanted one or the other the change could be made by purchasing a new controller.
IMO there is no need for the AC/DC unit, the 12 volt model works great, there are no performance increases with the AC option. If you are a person that wants to keep the fridge on all the time (plugged in) and the battery disconnected then they would be more of an option.
One of the reasons people worried about the DC fridge, was the possible chance that the turn on current, would transition a charger that was in the float stage, back into the absorption stage, and thus overcharging the batteries. It is a possibility that could happen, I never saw it in 17 years of owning my sportsmobile, that was plugged in all the time and monitored more than most rigs.
And, as said previously a problem with the AC/DC unit was when on the inverter, it would default to AC, drawing more power. Again not a major problem, that couldn't be taken as long as the fridge was on it's own breaker or switch.
The CR130 is a very nicely sized unit, my biggest complaint is that it wasn't well designed for airflow, so you should have concerns when putting it into cramped spaces.
Saving money with truckfridge, you could apply that to a device called the
Merlin II , a smart speed controller. It can give you energy savings, and it also has a warm start feature for compressor thus reducing stress on the overall unit. The merlin will plug directly on to the controller. It can be used on a AC/DC unit but would need to installed remotely as the tabs are closer on that controller.
There is also an LED for flashes for various issues that the fridge may have.
If you have a Chef for a wife, don't put a thermometer in your fridge, Or you may have to move to something like this
digital thermostat Yes, it is a little overkill, but you won't have to worry about turning the knob up or down anymore.
The previously mentioned Isotherm ITC looks like in incorporates both of these type devices in one package. I will say that when I tried the predecessor "smart energy controller" I found that the the high voltage overcool feature somewhat useless in saving power (with solar), but I see that they have an eco switch that disables that when camped.
