Old 12-30-2019, 10:18 PM   #221
EliEliO's Avatar
Are these still an option? If so I’m in for a driver and passenger for my 2013 to 95746 please. Thanks!
EliEliO is offline   Reply With Quote
Old 01-25-2020, 07:41 PM   #222
Did you ever figure out what the “yaw” was for?
Have the same thing and just removed it but wondering exactly what to do now.
wandrly is offline   Reply With Quote
Old 01-25-2020, 09:32 PM   #223
Darkstar's Avatar
I think that yaw rate sensor ties into the traction control and could cause the check engine light to come on, but there should be a way around that. I just re seated it to not take the chance..
Darkstar is offline   Reply With Quote
Old 01-27-2020, 03:11 PM   #224
Thanks Darkstar. I posted on my other thread, but if this is what I think it is, based on some research around the web, then when it malfunctions (and possibly / probably if removed) the RSC / AdvanceTrak system goes haywire and will try and compensate for absolutely no reason when you're just driving down the road.
Doesn't sound like you've experienced that though, so a simple relocation hopefully is just fine. I did the same thing you showed on your post, with the block of wood cut out for the V plastic. Thank you for that!
Old 01-27-2020, 03:41 PM   #225
Darkstar's Avatar
Glad it helped.. I just got done putting in a Propex Propane heater ...that was a long time coming project.. always tense when you are drilling big holes in the floor... but copper line is run to propane quick connect on bumper all good!!
