Old 09-09-2014, 11:34 AM   #161
Re: Look what just drove up in my driveway, it's Rusty!
Originally Posted by shenrie
thats a slick setup, well done man!
is it a one person job to get bed up there?
Oh yeah, not heavy at all, and I have lots of pillows and crap on top of the bed. You lift up and hook one end at a time, you don't have to lift the whole thing.
Old 09-09-2014, 08:18 PM   #162
How the hell did the 3 piece bed work Eric... you had to stack them somewhere out of the way?
Old 09-09-2014, 09:02 PM   #163
Yeah, and it was a pain. You could stack em all at the back or stand em up back there. I know you and most folks have a 50 and Nancy from SMB Indiana told me the 50s were the only ones with a two piece bed up until a few years ago. In other words they were all 3 piece on the older ones, but that doesn't really make much sense to me. I have scarcely seen a 3 piece other than mine.
Old 09-10-2014, 05:53 AM   #164
BrianW's Avatar
Mine is a 98 Indiana build and has a one-piece bed. It's a walk-through floor plan though.
Old 09-10-2014, 09:44 AM   #165
mikracer's Avatar
My 95 has a 1 piece bed and its a RB30 layout. If I would have seen that you needed a pic of the way it mounted, I would have sent you some pics. Pretty sweet fix you did there!
Old 10-17-2014, 07:48 AM   #166
JohnandMandi's Avatar
We got to tour this van at Expo East and can only say that Eric did a terrific job of fixing it up. A great save.
-John
2001 7.3 E350 Ujoint 4" w/ SMB Penthouse
johnandmandi.com
JohnandMandi is offline   Reply With Quote
Old 10-17-2014, 08:56 AM   #167
Thanks John, and it's not done yet! I'm planning on-board air and solar as we speak. I'm also ditching the lousy 8/9 gallon fresh water tank in favor of a 25 gallon mounted underneath where the rear Transferflow used to be.
It truly never ends.......
Old 10-26-2014, 08:54 PM   #168
LED courtesy light mod
viewtopic.php?p=140382#p140382
Old 10-26-2014, 09:20 PM   #169
Reunel rehab Part II, rear bumper
It looked pretty rough.
The plan was the same as the front, matte black finish and truck bed liner/non skid coating on the surface. Also, adding an Aluminess spare rack and ditching the older style SMB A-frame carrier that kept my door from opening more than halfway.
I'll skip the grinding, brushing, rust removal filling and sanding. It was pretty slow and boring, and every time I start doing it on something I'm too cheap to buy new, I hope I will never have to do it again. Here are a couple of pics of the process though.
Oops, sorry for the sideways pic.
Why do you labor, Master? You could just relax like me.
Finished product before install.
What I removed.
Also ditched the leaky, rusty Transferflow. I was going to add an underfloor storage box here, but instead I'm opting for 25 gallons of fresh water and onboard air in this location. Also, this is the only part of the underside of the van that was not sandblasted and painted/undercoated this past winter because the tank was in the way. I'll be addressing that before installing the new goodies. the good news is the angle iron cross members added for the Transferflow to strap to are perfectly spaced for the water tank. No need to do any welding under there at all.
Removing the upper door hinge pin was the most difficult part of this install. Thanks WVvan for lots of pics etc. in your build, but mine was still really tough. I wound up removing the hinge completely and getting some help from a friend with a bigger hammer. Dave from Aluminess has since given me the quick, easy way to do this. Air chisel with a pointed big. Dammit. I have one and didn't even think about it!
There was much less drama mounting this one, except for a really good fit I had to notch out the Reunel for the Aluminess carrier. This involved lots more grinding and cutting, then REsanding, REpriming and REpainting. Ughhh. Anyway, finally on.
I'll get the lights wired up eventually.
Old 10-27-2014, 07:12 AM   #170
BrianW's Avatar
Nice job (as usual)! Did you move the old driver's side tire mount to the passenger side as the base for the generator box? I've been thinking of doing that on mine, too (well, getting another tire mount). Would be nice to be able to run an outside box, but I don't want to spend the $$$ on an Aluminess setup.
EDIT: Just looked at your gallery and I guess you had that box setup before moving to the Aluminess carrier. If you want to sell the old spare tire mount, let me know...
Turtle
rafeman
BigRed4x4
BigRed4x4
