Originally Posted by ScrapIron
Got the heavy duty hellwig swaybar installed. Much heavier than the factory unit i removed. I had one of these on it a few years back when it was still I-beam suspension and found it was far to stiff so i removed it and got rid of it.
But it feels just about right with the 4x4 axle under the truck at this point.
Helwig shows the following Front and Rear respectively.
92-08 E250-E350 Single Wheel 7604 1-1/8" 7183 1-1/4"
I bought the Addco bars
Part Number: K1-548-0U-352 1 1/4" Front
Part Number: K1-697-0U-350 1 1/8" rear
These compare to the stock bar which I think is only 13/16" IIRC
I'm looking to optimize highway driving and stability not off-road. I've used Addco bars in the past had they have always been plenty without being too much (1969 Datsun 2000 and a 1984 VW Westfalia). On the VW the front was exceptionally good while the rear seems to do little with the front one.
What size bars are you using and do you think they are too much for highway use on a E-350 RB 2WD?
