Alright stinking sway bar is in, let's see if this helps. Install was pretty easy and straight forward. Just realized a disconnect on the rear will be tricky since the bar needs to basically be in the same position, maybe have a bungee setup where it's disconnected and hangs from a bungee to hold it in basically the same place but allows it to stretch and flex instead of limiting the axle??? I dunno what else I could do to keep it off the frame
