Old 07-20-2019, 05:16 PM   #2851
Originally Posted by larrie View Post
We use to carry our traction boards and shovel on the roof rack. It was a pain to climb up and get them. Looked at different mounting systems for them and ended up making my own. There is no movement when on rough roads.
Cut a round piece of 1/2” plywood with top and bottom slots. Added mounting bolts and a couple of mounts for a shovel and an axe.
The plywood fits tight against the tire.
And is held in place by 2 inch ratchet strap.
That's a great addition. I always have a small shovel, sometimes a full size one, but never thought of carrying traction boards.
skoronesa is offline   Reply With Quote
Old 07-22-2019, 07:42 AM   #2852
vandiesel's Avatar
That is genius.
Old 08-08-2019, 02:16 PM   #2853
Finally installed rear pop out windows. Yes! Been hanging onto them for a couple months. Thank you LA craigslist rear pop out window guy
Next up, painting pop out specific rear window trim pieces. They are currently tan. Anyone know a good plastic spray paint match for Ford interior grey?
Jean Claude Van Dad
killacks is offline   Reply With Quote
Old 08-08-2019, 02:52 PM   #2854
Fool120's Avatar
ACR install, sawy barbushings and 2nd handle on door
I got a few things going this summer: finally installed the Blue Sea ACR, with linked battery setting for starting, installed the anti-sway bar bushings, and added an extra handle on my side door. The Blue Sea ACR (Automatic Charging Relay) lets a charge at either battery bank charge the other, as in alternator charging one way, and solar panels the other. Who can also isolate the batteries, or connect them all to start the engine when there's an issue. To use the start feature who need heavy wire, I used 2/0 marine cable. The hardest part was figuring out where to run the cable, and later running it. I've been sitting on these anti-sway bar bushings over a year, thinking that I needed an air hammer. They were a bit of a pain to get the old ones out. I don't have an air hammer, so used just a hammer, bead blaster and a chisel. My Van came with just the lower handle, which is great when you're down below, yet the upper handle is best when you're in the Van. Newer versions seem to only use the upper handle placement. Now I have both. Will head out soon to test all these things. Happy Traveling.
Rob
'97 Ford E350 EB 7.3 PSD
Quigley, Sportsmobile
Fool120 is offline   Reply With Quote
Old 08-10-2019, 10:35 AM   #2855
bigriver's Avatar
Running Boards or No Running Boards
I've been trying to decide what to do with the old running boards on our E250 EB30. I thought I'd just take them off but when I did that the grey water plumbing, propane rig and starcool works were all showing hanging down below the body line. So I Rhino Lined em black and put them back on. I like it!
Joe
2003 EB50 7.3L PSD Q4X4
2003 EB30 - Sold
Old 08-11-2019, 08:03 PM   #2856
I replaced the pop top gasket, never a fun job, they seem to last 7.5 years for me as this is the second time. I have a 12' and a 6' scraps left if anyone wants them.
PatO is offline   Reply With Quote
Old 08-18-2019, 05:07 PM   #2857
wanderers's Avatar
I replaced my Fantasticfan with a MaxxFan. I did it mainly because I've had rain come in a few times when I wasn't expecting rain and I wanted more ventilation when it was raining. It is very quiet on the lower speeds with a correspondingly low current draw so I should be able to let it run all night. It should help vent heat from the refrigerator when it's raining. It does stick up a bit more than my other fan. I hope the extra drag won't affect my MPG to much, it is somewhat flat in front.
wanderers is offline   Reply With Quote
Old 08-18-2019, 05:12 PM   #2858
Otter's Avatar
Aluminum Cargo Basket
Got my cargo basket installed. It’s all aluminum and as light as a feather.
Old 08-18-2019, 08:23 PM   #2859
I replaced the rear pop top latch with the new style available on the Sportsmobile Store. A very nice design. I will also be replacing the 2 front ones when I get motivated again.
Old 08-23-2019, 05:14 PM   #2860
larrie's Avatar
Finely got around to replacing the backup camera today with a eRapta ERT01 from Amazon. Had to remove a bunch of trim pieces in the living area and also pull the panels off the dash as well as the head unit to run the wires. It took most of the day for the entire project. It works great.
Larrie
2006 Ford E350
Belize
Dodge
lugee
