What initially started out as a simple oil change turned into soooo muuuuch moooore:
Have had my eye on a Fass Titanium signature series double filter Fuel system – figured while the Van was there, WHY NOT – Right???
Replaced the Oil cooler just to see if it would change my delta’s. Initially had averaged around 10-11, and now after a couple 1 hr trips it looks like its down to 8-9 – Not a marketable improvement, just eased my mind.
Even though it was only 5 years old, replaced the BPD EGR Cooler at the same time
The Brake system on the Van always had me somewhat concerned: When built by Sportsmobile, the Van had the Big Man Brake upgrade installed, and as recommended I had the Calipers removed and sent back to CA to be rebuilt. Shop doing the work discovered the Rotors are actually too small for the set-up, so also replaced the Rotors with larger Wilwood Rotors (unfortunately still as expensive as the Brake Man rotors)…Hell, since they were deep into this I decided not to stop there, had them change the vacuum brake system to Hydro Boost (Every hose, tube, and pipe assembly & bracket replaced, along with a larger cooler installed); collectively these upgrades made a
HUGE improvement on braking! (Worth every $$$ invested)
***Picture of parts list they provided me is in my album if anyone is interested:
https://www.sportsmobileforum.com/fo...ture42630.html
Took the liberty to replace the EPB sensor and both ABS speed sensors (very happy the Sportsmobile build books came with the Van when I bought it - At first the "new" ABS sensors triggered the ABS dash light...until I glanced at the spec's of the build and realized those are also a "custom" change - Put the recommended ones on & no more issue)
Sway bar bushings and end links replaced – Was ready to upgrade to the ARB Ball joints, but everything else was still nice & tight, so decided to leave that for another year.
Installed the rear LED Tail Lights from Scott at Vantage Optics – Look very nice and distinctively brighter than the OEM’s.
***Now just need some time off work so we can get out and enjoy ourselves.
