Thank you. There’s nothing in the manual about equalization or tail current. There is this though:
The BAT SIZE A/H control is used to inform the inverter's microprocessor of the battery bank size. This allows the inverter to make better “over-discharge protection” and battery charging decisions. Battery bank size is adjustable from 50 to 1000 amp hrs.
The control is a dial with minimal markings so I’ll attempt to set it to 200 (I have two batteries).
Unless there’s a chance of damaging the new batteries, I’ll give it a go with the existing inverter/charger. I now have a battery monitor so I’ll be able to check the voltages with both settings. Appreciate the info.
