Old 03-13-2024, 12:07 PM   #1
Pimpon's Avatar
Pimpon new loc lights
I want to modernize my front and rear lights
I can't find the discussion with the lights https://www.vantageoptics.com/
For the rear, there are other models or not https://www.amazon.com/ZMAUTOPARTS-E...010154L9E&th=1
-1995 E350-7.3 Quigley -1993 Toyota HJD 80 -1990 Toyota HZJ 70 -1980 Toyota BJ 42
https://www.facebook.com/profile.php?id=100064197488075
Pimpon is offline   Reply With Quote
Old 03-13-2024, 01:46 PM   #2
Twoxentrix's Avatar
Vincent here are several Vantage Optics Threads:
FYIW:The HID's do require wiring in a ballast & the LED's do not - I've used both and you can't go wrong with either, but would recommend purchasing the side marker light replacements at the same time (also available from Vantage Optics):
https://www.sportsmobileforum.com/fo...-14304-73.html (Last post has a current "Discount coupon code")
https://www.sportsmobileforum.com/fo...wap-32238.html
https://www.sportsmobileforum.com/fo...hts-31640.html
https://www.sportsmobileforum.com/fo...ech-30434.html
As far as the tail lights go, I used these (and pleased with them, but are several versions available out there when you do a Google search):
https://www.amazon.com/Parts-Go-1995...%2C105&sr=1-27
Old 03-14-2024, 11:56 PM   #3
Pimpon's Avatar
There is no longer your model too bad
Old 03-14-2024, 11:59 PM   #4
Pimpon's Avatar
There's this one that's not bad too
https://www.amazon.com/gp/product/B0...DKIKX0DER&th=1
Old 03-15-2024, 07:42 AM   #5
Twoxentrix's Avatar
I thought I may have copied the link incorrectly, but when I open the link it shows the product with no problem...here it is again (and shows it is 'in-stock'):
EDIT: Now Amazon has a message which appears across the top of my page that states " AmazonConfirmedFit: This does not fit 2006 Ford E-350 Super Duty".
I can only assume someone must have reported it doesn't fit, Yet I ordered these and they fit fine (& have been on my Van several years with no issue). Maybe they changed something over the past couple years. The ones you linked look good also.
Old 03-17-2024, 02:15 AM   #6
Pimpon's Avatar
I just looked, it's not easy to order, there are options and I'm afraid of making a mistake
https://www.vantageoptics.com/shop/F...Kit-p366172879
Old 03-17-2024, 04:01 AM   #7
Pimpon's Avatar
Can you order my rear lights because Amazon does not want to ship
Old 03-17-2024, 08:18 AM   #8
Twoxentrix's Avatar
Sure Vincent, I'll gladly order & ship again
Are you sure the link you supplied will fit your Van? I am no expert, but do not see any mention of an E-350 Econoline Van???
Being a considerably larger box than what the differential Bolts were shipped in, the shipping cost will probably be about the same price as the tail-lights...are you OK with that?
Old 03-17-2024, 08:54 AM   #9
Twoxentrix's Avatar
Also Vincent, PM me again about the Turbo - you sent me the links for 2 Web sites but they were for the 'home' page - you didn't specify what you wanted ordered.
Again, the weight and size on the turbo i'm guessing will run upwards of $250+ to ship to France.
Whatever parts you decide on, just order & Pay BUT have them shipped to my address (same as before), then I'll forward to you.
Old 03-17-2024, 10:18 AM   #10
As per Twoxentrix - this Amazon link works for me ! Good luck !
The YURT
MKRyan
Tan Hot Dog
Jsweezy
