Old 03-12-2018, 08:02 PM   #41
Thanks for pursuing this, TwoXentrix. Hope you can score a retroactive discount for yourself!
Jack K is offline   Reply With Quote
Old 03-13-2018, 05:59 AM   #42
marret's Avatar
+1. I hope so as well. Thanks.
Chris
Old 03-13-2018, 11:22 AM   #43
Originally Posted by Zappo View Post
I think the truck claws are great as previously posted but check these things out,they look legit and you get friendly info from Aussie girl
These look like they work great, but it's clear they are simply lengths of what we call Chemgrate. Available in ton's of different configurations, sizes and colors. I've seen scraps for sale at used equipment / industrial recyclers too. One would need to study the specs though to make sure you got some that's strong enough to hold up your van. Cutting the stuff is a chore too, it will eat up the blade on your saw pretty quickly.
https://www.grainger.com/category/fi...ecatalog/N-c16
Old 03-13-2018, 11:43 AM   #44
Jeffrey's Avatar
A similar alternative but a bit safer than metal is the trac grabber. Same idea and they have a big truck tire version as well.
Old 03-13-2018, 12:00 PM   #45
MountainBikeRoamer's Avatar
FYI, reviews on Amazon for those cheaper rubber tracgrabbers are kind of middling. Seems a fair number of people report breaking them. (At least one picture of torn rubber traction pad.)
https://www.amazon.com/Trac-Grabber-...8NM?th=1&psc=1
Mike T
___________________
'95 Ford E250 RB30 PH
Old 03-13-2018, 12:47 PM   #46
Ya looks like you could get several uses but depending on terrain etc might get shredded but cost is low,good lookin out Jeffrey!
Zappo is offline   Reply With Quote
Old 03-13-2018, 12:54 PM   #47
It also gave me an idea for a traction board,I’m about to change my Ktm dualsport tires and I think I’m going to take some weather treated board from Home Depot & cut the tire so I can screw down/flatten out(I think it could work good having semi worn knobbies gripping against all terrain type tires instead of just smooth all season tire scraps from local shop,i will post some pics here when I’m done in about a month and might even try doing a small video on the beach in mex.it might even be worth a few laughs! If it does end up working you can get free tires from any local performance shop or motocross track as they are always laying around.the max Trax look real nice mounted on rigs but it pisses me off that if your tire spins they wear out so quick(it seems).
Old 03-13-2018, 03:53 PM   #48
Jeffrey's Avatar
I read through the first six pages of reviews and they were overwhelmingly positive. Most bad reviews were because owners were buried in sand, and these devices do not excel in sand. One owner was wise enough to suggest that you crawl out slowly and not try to accelerate too fast. That sensible. And too muchh torque at once will lend to breaking under undue force. Of course, every user and situation is unique and online reviews are an easy portal for all blabbermouths. I don't expect miracles but common sense and lot's of experience in 'getting out' will help in using these properly. Seems a good addition to the MaxTrax, Treds, winch, highlift with wheel lifter and shovels that I usually carry. Even some mud can be a challenge. And the manufacturer is selling them for less than any ebay deal or seller I saw. $99 for 4 that will fit my 35" tires.
Old 03-13-2018, 05:19 PM   #49
Twoxentrix's Avatar
They allowed 2 weeks to order with the discount below.
At least they finally made a decision...This is the offer they decided on:
Discount code is SPORTSMOBILE2018 for $30 off TruckClaws II and TruckClaws II with Extender Bar Kits. Code applies to as many units as they add to cart. Offer expires 3-27-2018 11:59pm Eastern.
https://truckclaws.com/
Regards,
Nick
I have no affiliation, just became a conduit for them to address the members on this Forum. $30 off isnt bad, IMO they certainly are a quality product
Old 03-13-2018, 05:23 PM   #50
Good deal!
