Old 03-26-2010, 07:03 PM   #11
AndrewST's Avatar
Re: Swiss van for the time in the US
Greydawg,
You are correct, I tinted the rear windows and will put insulation in between the window and the side panel.
At this stage, the plywood is used as a template, I plan on using some lightweight composit panels.
Just getting the samples now.
I am planning to replace the aft side windows with fiberglass parts but not right now. That will b e for a futur upgrade.
Andrew
Old 04-02-2010, 06:50 PM   #12
AndrewST's Avatar
Am doing some work on the bench support to move it back and tilt it forwards.
Will post the pictures when finished.
I weight the van, empty it is 7220 pounds. Heavier than I thaught...
More soon.
Old 04-02-2010, 08:17 PM   #13
Great job! Keep up the good work and keep the pictures coming.
Rick
02Chevytonner is offline   Reply With Quote
Old 04-06-2010, 05:04 PM   #14
deminimis's Avatar
Andrew has been busy working on the van pretty much every day. I can't wait until I get to take the Super Sawzall to that roof!!!
Old 04-06-2010, 05:31 PM   #15
pics!!!
Old 04-06-2010, 05:46 PM   #16
bettyford's Avatar
That is the fun part for sure. I did mine last week and it came out great. although the look on my wife's face when she realized I had just cut a big hole in the top of "her" Van. It was the perfect time for me to say see honey you weren't listening when I told you what I was doing, but I know better than to say that. I do feel better that I got to tell you guys.
Thanks
Ron
Going where most dont
"one day at a time"
Old 04-06-2010, 06:40 PM   #17
Are you going to cut his refrigerator in half too?
Old 04-06-2010, 09:01 PM   #18
AndrewST's Avatar
Originally Posted by billwilson
pics!!!
Let me finish the part I am doing and you will have the whole story.
Partially would be hard to get...
Cuting, grinding, welding steel parts
Old 04-06-2010, 09:45 PM   #19
deminimis's Avatar
If Andrew buys a NORCOLD, then yes, I'll cut it up, right after I finish going all Pulp Fiction with it.
Old 04-07-2010, 09:18 PM   #20
AndrewST's Avatar
Hummm, might be time to hide the super sawzall... if the Pulp Fiction mode is activated... don't know where it will end...
I went a few steps further so here are the pictures...
I worked on changing the factory bench support into my own brew in oder to move it backwards a little and be able to tilt it forwards.
Welding the pieces bolted to the upside down bench, aligning and protecting...
Done
And I needed to remove the rivets holding the locking system that I reused.
I didn't have the good way of working for the first one so the thumb didn't help much but was on the way of the hammer
The original support
The modified one in place
And all this to be able to:
It isn't finished, I now need to finish welding the base and test it once the swivel bases come.
Then see how can I fasten the bed on the back of the seat.
If you wonder what I have in mind, it will be something like this:
More to come...
Moby
maptester
Tan Hot Dog
Jsweezy
