10-27-2020, 03:11 PM
#131
Originally Posted by nyyankees588
Not to bump a somewhat old thread, but just wanted to thank everybody that contributed to this........ Cruise control now works perfectly!!
Glad this info was helpful and thanks loads for the update!
11-05-2020, 03:30 PM
#132
I have an 04 e350 v10 with factory CC. Stopped working. Happened a couple of years ago too and was remedied by replacing MC pressure sw. This time it is not the pressure switch. I jumpered the connector to eliminate possibility of intermittent failure, still inop. Not sure where to go from here.
I do have an eight page" Mitchel Manual" "Speed Control Diagnostics" document that is specific to 2004 E350 as well as a few other select ford models. There is a speed control module self test both static and dynamic, however it says to do different procedures and watch the speed control lamp. But as JWA said about his, I have no speed control lamp in my dash.
Anyone have any idea what to try next?
Joe
11-05-2020, 03:47 PM
#133
It's most likely the switch set on the steering wheel, they go bad pretty easy. And unless you buy new, you will go thru a few bad ones from the junkyards and ebay also.
11-05-2020, 05:23 PM
#134
Joe
Here is the TSB: tsb060805.pdf
11-07-2020, 05:45 AM
#135
No that's not always the case nor the most frequent cause of VSC failures. Since Wahoo's E-Series is 2004 it should still have the cable pulled servo connected to the throttle body. That device should be checked as well as brake lamps including the HMSL or "third eye" light.
Also there are three fuses potentially stopping VSC from working; F2.6 (10 amp) and F2.11 (15 amp) located in the Central Junction Box (inside the cabin). Additionally F1.6 (2 amp) located in the Battery Junction Box under the hood.
Note Fuses F1.6 & F2.6 are hot in run only, Fuse F2.11 is hot at all times.
HTH
11-07-2020, 07:43 AM
#136
Actually you're incorrect, its pretty common and most likely the cause at that mileage
11-07-2020, 03:41 PM
#137
HTH
Thank you JWA.
All three fuses ohm out good. F1 and F2 #6 are hot in run and F2.11 is hot at all times. And all three brake lights work.
Not sure how to check out the servo.
11-08-2020, 07:31 AM
#138
You can test your switches by ohming them out with a multimeter, and having a friend there helps to hold and hit the button while you test for continuity. In my experience it's the "on" or "set" buttons that go bad, assuming because those are the most used. Beyond that, it's unlikely that your actuator is bad but def is still a possibility. Theyre on ebay for sale, hard to find at salvage yards sometimes. And I def recommend buying a new switch set if you figure out thats the problem, buying a used set or salvage set is risky, I went thru 3 salvage sets before I found a good switch set
11-08-2020, 09:17 AM
#139
Thank you JWA.
Next step is to obtain an EVTM for your year which has ohm resistance readings as they'd be measured through the VSC system. You would unplug the servo (under the hood) and probe its connector for the correct and/or existing readings as each steering wheel switch is pressed---those values are part of the VSC schematic pages. If all those check out its the servo itself. Since you've ruled out the fuses and confirmed the brake lamps are working its down to what readings you'll obtain at the servo connector.
If its the servo and there's one available for your year it will be PRICEY. Although these tend to be very year specific there is a YouTube video showing possible compatibility of servos fitting an application they weren't (supposedly) designed to fit. See that here: |
Please note the complete servo is actually two parts, the motorized portion pulling the cable and the electronic control head attached to the servo case. That will be shown in the video.
I'm not one to prowl scrap yards in search of parts like you might need----if they're available new I'll always go that route for convenience and a good chance they'll work first time out.
HTH, PM me if I can be of further help.
