Old 01-05-2015, 08:54 AM   #201
Re: Look what just drove up in my driveway, it's Rusty!
Nice! I just black rattle-canned my panel as well......couldn't handle the silver frame.
What did you use for getting the wire through the top? A bulkhead connector of some sort?
Old 01-05-2015, 09:17 AM   #202
I drilled for the wires just behind the front mounting bolts (that you can barely see in one of the pictures), so it is outside of the canvas, then I brought it through between the canvas and top in the corner and through a hole in my interior roof panel. Since it's outside of the canvas and I'm not worried about an interior leak I just used silicone around it.
Cool Jacktuppvan! Good to have a fairly close neighbor. I'm over in Maryville.
Old 01-25-2015, 01:39 PM   #203
SCBrian's Avatar
Spotted!!
Great to finally meet Eric. His hard work really shows!! We recently met up at the SEES event from over on Expo Portal; Country Fried Weekend down in Suches, GA last weekend. His van was well received and he was showing it off all weekend.
Hopefully we can get another trip together this spring or early summer.
2001 E350 V10 Homebrew
My Build Thread
SCBrian is offline   Reply With Quote
Old 01-25-2015, 03:02 PM   #204
twogone's Avatar
I loves me some camouflage tires!
'95 SMB E350 Quigley 7.3
https://www.taylorarts.com
Old 01-25-2015, 05:50 PM   #205
Thanks for posting Brian! Yep, great to meet you and hang out as well. It was a great event.
Old 05-01-2015, 02:45 PM   #206
gnty's Avatar
I have no idea how i've missed your thread, i just spent a bunch of time reading it. What an amazing job you've done!! A real inspiration to all of us to tackle project like that and to have a vision of what you want it to be, and then go after it full force. Again, very well done and thanks for sharing!!
gnty is offline   Reply With Quote
Old 05-01-2015, 05:28 PM   #207
Thanks amigo! I appreciate it. I'm building a garage right now, or an SMB cave more specifically, which I guess I should just add to this thread. It's going to allow me to build my next one and finish with a few things I still have in mind for Rusty. It's never done for me I guess.
Old 05-07-2015, 08:18 AM   #208
Kitchen, pantry box mod. NO FRILLS!!!
viewtopic.php?p=154393#p154393
Old 05-12-2015, 01:15 AM   #209
buckkiller's Avatar
Wow van looks great bud
"The Redneck Mexican"
2002 E350 EB 7.3 Clydesdale 4x4 w/8' lift,
Colorado Camper Van pwr top,
Van Specialties build out
buckkiller is offline   Reply With Quote
Old 06-08-2015, 04:39 PM   #210
Time for a an update. I've continued to tinker a little bit with Rusty but mostly these days I'm just enjoying it. We've put 16k on it in the last year and a half or so for a grand total of 35k. It's hard to believe it's so young yet so old.
Anyway, in the south we need AIR CONDITIONING! Actually, mostly we just need it for dehumidifying. "It's not the heat, it's the humidity". I had thought about this idea for awhile but it was on the fence due to having to cut my front screen. My pop top is older before the screens zipped out. Many thanks to Mpfreivald (username) for pushing me over the edge. You can read about this cheap and easy mod here:
viewtopic.php?p=132907#p132907
I did essentially the same thing, but with a couple of small things different, mostly for my personal storage needs. Everyone's floorplan and personal needs are different so I wanted to show a different idea of how storing this setup can be minimized. Also, my PH fabric is old and in pretty bad shape. I recently tore the clear plastic on one of my rear windows. The shock cord around it is breaking down, and it just basically needs replacement sooner or later. I priced new fabric at about $800. I figure if this doesn't work out it will just put me closer to getting new fabric, and modding it for the air before I install it.
First, and worst, cut the screen.
There is a pretty big overlap in the canvas and screen, at least on my van. So much so that I was able to add a few snaps to the screen so I can put it back together when not using the air conditioner. The slits up the sides are still there of but I'm considering some strip magnets or something if it's a problem. Of course, I can still close up the front canvas and just not have the window and everthing is still usable. I can even adjust the zipper to just have either corner of the front canvas opened.
To install the AC, unsnap the screen and roll it cleanly down with the canvas
Here's the frame and support I came up with, essentially the same as Mpfreivald's, but it breaks down a little smaller for storage. No PVC is glued.
With AC in place the cord can be routed behind the front counter where I put in a receptacle for the coffee pot.
Then I made a cardboard template and replaced it with a fluorescent light diffuser from Lowe's ($10). These are very flexible thin plastic in a variety of styles. I chose a cracked glass looking one that would still let plenty of light in with the air conditioner in place.
Once I got it right I cut it so I could store it easier. I attached it in the middle with a LOT of packing tape, still flexible but won't fail for awhile and you can hardly tell it's there.
For now I'm using pipe insulation to seal everything, but it's kind of bulky and a pain to put all the little pieces in place. Still just about two minutes to set this up but not ideal IMO.
Here's another big reason I hesitated on doing this. Where to store? I didn't want to have to make room for lots of random, odd shaped pieces. Here is the AC stored, which won't need to go with us except for summer trips.
And here's everything else
The bag with the frame and insulation is light so it goes in the roof box and the clear plastic goes folded behind the driver's seat.
Thanks again to Mpfreivald for a great idea to build on!
More to come............probably
