10-22-2021, 10:22 AM
#101
Here are some more great ideas copied with permission from the Facebook Sportsmobile page:
Anyone interested in a super stealthy ignition bypass switch for the SMB? Or just about any other vehicle? idea #1- 1 12vdc relay tied to the passing lamp circuit set up to make/break the start signal. You would need to pull back on the passing light switch while using the key to start. Idea #2, Use the passing lamp switch relay in series with the brake switch/shift solenoid circuit so that passing lamp and brake pedal must be active to switch out of park. Idea #3 Use the horn switch with a latching relay to activate either the ignition or close the start bypass circuit, the horn wont actually blow unless the engine is running via oil pres switch. Just plain old bypass switches on either the start signal or the ignition could work but I like the idea of the bypass switch hidden in plain sight!
I'm thinking #2 is the way to go even passengers wouldn't realize i'm activating the bypass to switch out of park, even if someone had the keys it would be difficult to figure out, best of all its automatic every time you go into park. I can run into the gas station and leave the AC on for Pupper. I also like to pre-warm my engine leaving the van sitting in the driveway running. Any ideas out there?
10-22-2021, 10:59 AM
#102
Good ideas.. create a puzzle. Low-tech, inexpensive. Really like #2 - it's easy to hotwire the van and at least get it running, but if there's a hidden puzzle to get it into gear, that's likely enough to stop the theft.
10-22-2021, 12:25 PM
#103
Saw this on a EarthCruiser/Roamer? at Overland Expo East. I like the type measures that potentially have the dirtbag move on before he does the damage breaking in. The owner said it came on the vehicle. The same locking was used on 4-5 access points on the vehicle.
It uses a locking pin similar to the one you use on your trailer hitch draw bar.
Anyone seen them for sale before? Brand? I didn’t think at the time to ask how they were finished out on the inside of the doors…if they were thru-bolted.
Steve
2019 Yeti SB130 Turq Race X01
10-22-2021, 12:33 PM
#104
Interesting Steve. There might be some concern that someone could use that same security device (assuming a pin wasn't installed by you) to lock someone IN the van. A small cable would be enough.
10-22-2021, 12:36 PM
#105
Couldn't they just a) cut the bolt or b) break the window? I think they can always find a way to get inside, but disabling the van from moving with a multi-step puzzle ->might<- save the day.
10-22-2021, 01:49 PM
#106
I actually contacted Earthroamer about this a few years ago. It's proprietary and they don't sell them separately.
10-22-2021, 02:53 PM
#107
Oh well, that was my next move to call them and see if I could buy them over their parts counter, thanks for saving me some time.
Steve
10-22-2021, 10:42 PM
#108
Today I installed the Cyclops "Theft Avoidance Module". It's simply a relay that replaces your existing starter, fuel pump, or PCM relay and activates the relay only after you press a button on the supplied key fob. No wiring or splicing required. I replaced the PCM relay so that the starter still engages and sounds like it's trying to start. Very simple, reasonably priced at $150, and effective. I'll also use The Club on my steering wheel as a visual deterrent and additional level of protection. Next I'd like to install a Jimmyjammer or similar to deter break in.
https://www.shop.cyclopsantitheft.com/
Bardo
2005 RB-50 5.4L V8 E250 "Blanca"
10-23-2021, 04:25 AM
#109
I really like this. Thanks for posting.
I use a club like device that connects the brake pedal and steering wheel when parked in a place that it might be needed.
Chris
10-23-2021, 05:57 AM
#110
I like that idea, its a great compromise from a Ravelco and would certainly work to slow a crook down enough to run them off---maybe?
The RC relay would best suit me if it were gives some indication its been "armed"? Personally I'd like a pair activated by the same fob, one for fuel and one for the starter. That would give me notice perhaps one of the relays had failed if I encounter a no-start condition.
The Club in and of itself is not a huge deterrent to crooks----they simply use a hacksaw to cut the steering wheel.
Something like this? https://www.ebay.com/itm/33202798206...53.m1438.l2649
Those are interesting and wonder how much they'd dissuade or stop a crook?
