You gotta love a laser vendor who can take a drawing at closing time on Wed and have parts ready for you Fri morning! I whipped up a trans cooler mount design earlier in the week got it tacked together for a test fit. I like it. out of the way, safe from flying stuff, still leaves me room for other good stuff along the inside of the frame... I'll probably make a small shield around the CV joint to keep it from flinging grease into the fins.
Sealed relay (gets power from repurposed wires in factory harness) kicks on pusher fan when temp switch hits a set temp. Waiting on one fitting and then I can make lines.
