06-02-2013, 01:22 PM
#31
Re: Out with the Old and In with a Cummins
We're using the 47RH Dodge transmission with a 241 t-case. I had the tranny rebuilt & upgraded and we installed a SYE kit on the t case.
Just yanked the engine back out so we can swap the exhaust manifold & motor mounts. Also have some more parts coming from one of the Cummins swap specialists.
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
06-02-2013, 08:24 PM
#32
Originally Posted by E350
rebar: Are you saying that the Dana 60 full floating axle is not stout enough to handle the torque of the Cummins 5.9 24-valve?
I think its marginal.. You wont find a D60 behind any CTD in a factory application. In fact if I remember correctly, the dodge trucks switched a bigger D80 axle if the CTD was a manual, vs auto. I also found another pinion gear in a box in the van which tells me this isn't the first time my D60 has needed work.
Just something to consider.
The offset, or lack of with my motor placement, might also have something to do with pinion bearing failure. But I wont know which parts are failing until friday when my D60 gets new pumpkin bearings/shimmed etc. Its a temporary fix..
Darn.. I was hoping you were going to use a manual so I could see what it took before I started converting mine.. I hope that 47RH has some serious mods because the CTD is so brutally torquey.
1995 E350 cummins 6bt/nv4500, 24' surv toyhauler, DRZ400s
06-04-2013, 05:24 PM
#33
I don't see why that would affect pinion bearing- there shouldn't be pressure on the pinion after 2+ U-joints in the driveline. Torque and/or a bad setup- if you don't know who set up your new gears they might have done it wrong.
Also the pinion in the box, was it new? Because if they slapped in a ring gear, having chipped one or something, but left the existing pinion in the pinion might have been weakened by the previous failure.
06-04-2013, 06:47 PM
#34
Beyond that, ring and pinions are a matched set and should not be swapped around.
AgileOffRoad.com
06-07-2013, 08:02 PM
#35
Swapping out the Ford diesel for a Cummins seems like an excellent idea. I never thought of it for other than a pickup truck.
Here's a resource that might be worth checking out:
http://fordcummins.com/
2005 Ford E350 6.8L V-10 RB-50
07-20-2013, 05:20 PM
#36
just heard that Chris is back on the task. I guess had to custom build some motor mounts for it.
1994 SMB 7.3 with Quigley and Agile offroad goodies
1982 Wanderlodge Blue Bird FC33
07-20-2013, 07:07 PM
#37
We need a web cam in his shop pointed at your truck. Has anyone put in a 5.9 common rail
in a van yet. I cant wait to see more photos....
07-24-2013, 08:35 PM
#38
Sorry to say that this project has been cancelled. Our schedules for completion/pick up/etc aren't close enough so we decided to stop now and liquify everything we can. Lot of good parts coming up for sale!
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
07-25-2013, 12:10 PM
#39
thats too bad. was looking forward to this build.
07-25-2013, 12:12 PM
#40
wow!!! what parts will you have for sale?
