Old 05-24-2013, 09:05 AM   #11
E350's Avatar
Re: Out with the Old and In with a Cummins
Originally Posted by SMOKEKIKI
It would be nice to have pre fabbed engine mounts.
Here you go:
http://www.destroked.com/prod_motor_mounts.php
Old 05-25-2013, 10:40 AM   #12
rebar's Avatar
You will love it. As I do mine.
1995 E350 cummins 6bt/nv4500, 24' surv toyhauler, DRZ400s
rebar is offline   Reply With Quote
Old 05-25-2013, 10:49 AM   #13
E350's Avatar
For extra credit, how about explaining why?
How is performance/driving with two fewer cylinders?
How is the mpg?
Is it taller? I.e., did you have to do a body lift to fit the 6bt in?
Can you tell us what version of the 6bt is best?
And anything else you could tell us would be greatly appreciated.
Old 05-26-2013, 08:57 AM   #14
UJOINT's Avatar
Pics will be taken! We're using a 96 12V, just swapped everything from the core engine to the new jasper unit. We're doing this conversion for a few reasons. The 7.3 in Jeff's van was worn out @215k due to lack of maintenance so a new engine was needed. I brought up the idea of the cummins swap and jeff said lets do it!!!!!
I will say now that I won't be offering any type of kit for this swap. I'm undecided on whether we'll do another. It's a ton of work, so we'll see how it goes. Always hard the 1st time!!!
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Old 05-28-2013, 07:44 PM   #15
UJOINT's Avatar
Dressed and ready to install
1st test fit!
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Old 05-28-2013, 08:09 PM   #16
E350's Avatar
Pretty! And it looks like there will actually be room between the engine and the body under that van hood!
Old 05-28-2013, 09:38 PM   #17
You might be onto something there Chris! That motor just looks like it is designed to last 500,000 miles and they have good fuel consumption too I hear.
Old 05-28-2013, 09:39 PM   #18
shenrie's Avatar
awesome, very cool project! please keep up with photos best you can
are you going to try and mount turbo back on in stock location or relocate?
Old 05-29-2013, 07:22 AM   #19
UJOINT's Avatar
Thanks guys, we're learning a lot! We're going to play with the turbo mounting, need it lower and under the manifold for clearance. Trying to source one today, if not we'll just make it! There's a good bit of room on each side of the motor, will be easy to work on in the future.
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Old 05-29-2013, 10:29 PM   #20
webbmac is offline   Reply With Quote
