Originally Posted by Farmbro
So I found a full float Dana 70 out of a 2014 e350 with 4:10’s in it albeit not sure open or LSD but has the disc brakes already. Presumably a pretty straight upgrade albeit I suspect hub size will be bigger than 125 which is my current wheel set up? Width and spring perches etc should all line up?
This will be a direct drop-in. Hub diameter is the same. But beware it's 5" wider, and you'll still need the wheel adapters to match your front bolt pattern. Also... make sure it's not from a dually. Sometimes the wrecking yards aren't so good with their descriptions or cataloging.
