Originally Posted by PatO
I had to deal with rust on the gutters several years ago on my 2004. I sprayed it with an expensive rust control primer and then had the entire roof, gutters and under lip sprayed with Line-X. This was at the same time I had the pop top coated to take care of its extensive leaking and deterioration. I did all the pop top and roof prep myself and it cost around $1200 for the Line-X application. I have not had another issue with penthouse leakage, roof rub to bare metal or gutter problems since then. I have a few pictures in my gallery.
Pat
Considering
Line-X and
Corroseal Rust Converter Primer to re-seal the pop-top and fix rusting gutters.
Other suggestions?
